Powerboat Reports has a pretty good write-up on the current warfare going on among various navigation software manufacturers.
If you're in the market, you might want to look at the article:
http://www.powerboat-reports.com/index.html
Here are their "conclusions:"
"Your software selection will be guided by your need to support multiple computers, the type of interface supported by your devices (NMEA 0183, NMEA 2000, Seatalk, NavNet, Simnet, etc.), budget, and time available to learn.
If you have a Macintosh computer on board, then you’ll be happy with MacENC.
Our favorite Windows packages for pleasure boating are Chart Navigator Pro from Maptech or the Coastal Explorer from Rose Point.
If budget is the primary issue, then Fugawi offers the least expensive PC product here.
If you need to support multiple computers with redundancy, then Nobeltec Admiral and MaxSea are your choices.
If you have Furuno NavNet, buy MaxSea with the NavNet module. MaxSea has the most comprehensive feature list, but when configured with every available module (Pro edition is $4,400), it is by far the most expensive.
So long as NMEA 0183 remains in common usage, proprietary networks such as those provided by Raymarine’s Seatalk, Fugawi/MaxSea NavNet, and Nobeltec will continue to be necessary for many boats. As NMEA 2000 gains traction over the next few years and Ethernet becomes more common for high-bandwidth transfers, we expect that navigation software will be relieved of much of the responsibility for networking and that navigation software will be forever changed. Based on this test, PBR believes Chart Navigator Pro/Coastal Explorer, and MacENC (for Macintosh users) are in the best position to adapt to the changes coming in marine navigation software. "
Casey
C-Dory Naknek
Casey
C-Dory Naknek
