Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 16
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
Okay, I get it now. Thank you! I couldn't see in my mind how the whole run (say, windlass to breaker/buss bar/switch, and then breaker/buss bar/switch to batteries) wouldn't have to add together into one long run, but on the other hand, I thought it probably didn't. Now I know it doesn't.
I hear what you are saying on the small connectors sometimes ending up way oversized. I was using #6 cable for the connections in the lazarette, and some of them are very short, but I used the #6 anyway, just because it worked out fine that way.
Lewmar's instructions (to my mind anyway) made it very unclear as to whether they were talking about a round trip distance or a one-way distance on their "here is our recommended wire size" table. They said something like "The full run from the windlass to the battery must be considered." Now I know that both ways have to be considered, but when there is a chart, very often it has been "converted" to a one-way length for simplicity to the lay person. And they were not clear which way it was (IMO). So what I did was take it to a regular voltage drop calculator online and plug in Lewmar's figures; from that I was able to tell that they meant round trip. They listed #6 for up to 50'. I considered #4 for lower voltage drop because I thought I was going to be really close to the maximum, but as the run came out to "only" around 42', I think I'll be okay sticking with the #6 (which I already have two 50' spools of, not that that would make me use it if it were too light).
Now I guess I had better figure out if I am going to move battery(s) forward, because if I do then clearly I should just run the windlass wire straight to them (in which case #6 would be very very generous in size).
OR, am I going to connect the windlass to the start battery, which will be staying in the lazarette (addressed this in another thread).
Like they say... on boats... it's all connected! That can be a pain at times.
