matt_unique
- Joined
- Feb 27, 2007
- Messages
- 1,881
- Reaction score
- 0
- C Dory Year
- 2007
- C Dory Model
- 255 Tomcat
- Vessel Name
- Napoleon
thataway":2y0xsmuv said:I have to also correct for the engine being offset, It is only a little more than 1/8 turn, but there is definate pressure, and the boat would do circles if I didn't correct.The twin screw trawler I owned had to have rudder correction when running on one engine.
Matt, Did you say that you got on a plane with a single engine? That is just not possiable with my boat. I think I have tried all combinations of trim.--maybe I didn't trim the bow up enough--I'll have to try that.
What was your RPM Vs speed on a single?
I cannot get max RPM with the single engine. I do have lower pitched props and I could try that to see if it would plane the boat---however, I believe that it would be severely lugging the engine.
Since we are all farily close at planing speeds, I suspect that the lower speeds have to do with loading, attitude of the boat, and the accuracy of the flow meters. I did one fill up to fill up (about 200 miles), mostly at 7 knots and my flow seemed within 5%. But as you go lower, it will be less accurate.
I was able to get fully planed off with one engine. I ran the engine up to 3000rpm planed off as I recall and backed off from there. I did not check my speed for that test. I made a small correction to starboard, but it was not a significant as was expected based on what I read from others here. I was loaded light, just me aboard, no significant gear, perhaps 1/4 fuel tanks. I trimmed my port engine out of the water and ran with just my starboard engine.
