shad
Member
- Joined
- Aug 21, 2024
- Messages
- 42
- Reaction score
- 3
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
- Vessel Name
- C-Squatch
kennharriet":1xzsauhr said:Does anyone see any holes in this setup?
Not a hole, assuming I am looking at the correct Renogy DC-to-DC charger docs, but I would use 8AWG and 40A fuses for input and output of the charger. That way you only need one spare fuse size and wire size for the charger. 8AWG should be over-sized for the 20A load and distance between the lazarettes, so you should be good.
The lithium and lead negatives can usually be tied together for a non-isolated circuit on our boats. Non-isolated will save you from running an additional heavy gauge negative wire between the lazarettes. My setup has a negative bus bar in each lazarette with a single port-to-starboard 4AWG negative wire connecting the two batteries. Batteries with 4AWG to respective bus bars. Motors, house panel, dc-to-dc charger, and other accessories attached to the closest negative bus bar using appropriate wire gauge.
