leaking hydraulic Actuator Assembly
jbrosecity
Mar 14, 2016
8
2005
16 Cruiser
CDO16508H405
C-Scamp
my right Actuator Assembly has developed a small leak when the tab is lowered or raised... it is coming out around the top cap. I realize I can buy a new one... my same model is available on Amazon.
https://smile.amazon.com/Bennett-Trim-A ... B0006BJT00
But I was wondering if the Actuator Assembly is removed, is it possible to unscrew the top cap, perhaps, and merely replace a gasket or seal? There is some mention on the bennet website about O-rings and pistons. Anyone try fixing a leak like this before?
Send a PM or e-mail to Tabman Tom works for Bennett, and watches many forums for questions. He has been the "go to" guy. I believe he is still active, although he had some health issues a year or so ago.
You should be able to replace the seals, and Tabman, should get the right kit for you.
Thanks for the recommendation to email Tabman... I have done so and hoping he can provide some clues
joe
Joe,
How old is the Tab system? The first thing to try is to grab the cylinder body and give it a firm clockwise twist to see if that will tighten and compress the upper hinge O-ring and stop the leak. If that does not work send me your name and address and we can send you new O-rings and instuctions how to change them, no charge.
Tom McGow
Bennett Marine
Hi Tom... the whole boat is a 2005. photo here:
http://www.wind-seeker.com/temp/Bennett-trimtab.jpg
I'll try your idea to tighten with a twist. I guess it just rotates on the lower rod with the actuator in place? Or do I need to remove the actuator first?
thanks
Yes, the cylinder rotates around the shaft. No need to remove it from the Tab.
Let me know what you find.
Tom
Bennett Marine
ok I will try this later today when at the boat... will let you know how it goes
I am pleased to report that just twisting the actuator body slightly tightened up the seal and there is no longer any evidence of a leak... thanks a lot to Tom!
