Active member
- Joined
- Nov 21, 2004
- Messages
- 5,934
- Reaction score
- 4
- C Dory Year
- 2008
- C Dory Model
- 255 Tomcat
- Vessel Name
- Meant to be
All, I'm in Tofino for a fishing trip. I had an issue with the hydraulic steering today. I have a SeaStar 1.1 unit with a single helm station. I was backing away from the dock in heavy current (maybe 12kt's - it was so heavy I couldn't get untied without backing off against the lines). When I went hard over and gave a good bit of reverse throttle to get away from the dock, the filler tube cap (the one on the top of the helm station), blew off and I spewed about 1-2 oz. of hydraulic fluid in the cabin. Fortunately, I was looking out the back while pulling away from the dock and didn't get a face full or would have had a very hard time seeing in a fairly critical moment in time. Once I was safely away from the dock, I found the parts that flew off (the black plastic cap, an o-ring and a rubber like button (that I believe should be the venting part) and reassembled them the way I think they were in. The metal part for the fill cap remained attached to the helm. The steering seemed to be operating fine and did so for the remainder of the day. On the way back into the dock, the current was again in the same direction so once I got the bow to the dock I had to do a fairly hard reverse to stop the boat and crank the wheel over to bring the stern back to the dock. Again, the cap blew off and another ounce or two came out.
I was able to go to a local marine store and purchase hydraulic fluid and a replacement cap. The cap that was on there has had the plastic blown off the top and the 2nd time I couldn't relocate the o-ring that is internal to the venting cap. Until I bought the new cap, it wasn't apparent to me that the plastic part should never come off the metal part that threads into the fill port. So questions:
1) Have you ever seen this happen before? I have the manual and can read so I'm sure I can add new fluid and bleed the system. My suspicion is that it will work fine except in the odd circumstance of when I'm back at high power and have the engines hard over. Given that I've only lost a few ounces, I don't think it will be too hard to fill and bleed. However, I'm not sure if I should re-fill and bleed. What do you think?
2) What do you think caused the problem? My suspicion is that when I'm hard over and applying hard reverse throttle, I have a lot of pressure on the ram in a way that is unusual. However, I'd think that the system should be able to hand that. Once I refill and bleed, I will check the seals on the ram for leaks. I haven't seen any indication of fluid leaks near the engines but it's possible.
3) What else should I do or check?
4) If the hydraulic system fails will I lose steering completely or will it be more like power steering on a car - e.g. just really difficult? With the currents they have at the dock here in Tofino, a complete loss of steering could result in major damage to my boat and others around me if it happens at an inopportune time.
