hansonby
- Joined
- Mar 8, 2010
- Messages
- 17
- Reaction score
- 0
- C Dory Year
- 2009
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- WN 5550 RN
- Vessel Name
- SENIOR MOMENT
We were leaving the Penrose State Park dock this afternoon about an hour before low tide. We were about 200 yards out from the dock, heading east past the little jetty which protects the dock.
I had one eye on the Garmin 7400 Chartplotter depthfinder (which said 11.8 ft.), one eye ahead for boats and debris, one eye on the grandkids, one eye on the GPS map screen, one eye on the speed [6 kt.], etc., when the motors had a little audible hitch.
I looked over the side and saw the bottom up close and personal. Obviously I had hit mud and some rocks. I guessed the correct direction to steer and quickly got to deeper water and made it home with no further problems. The depth finder stayed at 11.8 ft. for a few minutes and then started reading correctly.
4 of the [aluminum]prop blades look fine - just "polished" a bit. One on the port motor is just a teeny bit scraped/rough, and one on the starboard motor has a rough, serrated patch about 2 " along the outer circumference with the deepest gouge about 1/16".
The two blades don't look so perfect now, but I assume they'll do their job just fine. How badly does one have to ding a prop before repair/replacement is necessary?
Thanks for your comments,
Byron
P.S. I had the depth alarm set for 3.6' and it worked when I came in yesterday to the dock at low tide. I have no idea why the depthfinder got stuck at 11.8' but it's been stuck before at various depths. I was right in the channel according to the GPS, and the depthfinder said I was okay, but still I hit bottom.
Byron
