A reciprocating saw would certainly be tool enough to get through the fiberglass but maybe too heavy and awkward to manuever. I used a skill saw with metal cutting blades, the wood cutting blades were wiped out by the abrasive fiberglass in no time. Even the metal cutting blades needed to be replaced after each hatch hole was cut. I think the verticle access behind the porta potti space is a great way to go. But in my case I wanted to remove the large water tank in the bow and thought going at it from above was easier.
There has been a lot of discussion about installing hatches, cost, size, and a bump under the mattress, etc. A good, cheap and workable solution would be to install access boards. All of my past sail boats had them under the vee berths. You can cut any size hole and then attach about 3/4 x 2 inch support battens underneath the perimeter of the cut out and then cut a piece of 3/8 marine plywood to fit in the hole with a 1 inch finger hole drilled near one edge to lift it out. I know all the former rag boaters out there know what I'm talking about. I imagine plenty of power boats used the same storage access method too.
Rich
Rich
