Chuck, no problem answering any question you might have on my trim tabs.
I little further explanation is required. The posts that I made earlier with
reference to the trim tabs, which Joe posted above (thanks Joe), are dated.
However the pics he posted are the current ...2nd generation of my mod.
A typical 9" x12" tab should have a surface area of 108". Lenco's 9" x 11" tab
has only 96" of surface because the tabs taper from 9" at the front (hinge)
end to the 7" at the tail of the tab. Very misleading. OK, I made a mock up
of a pair of wings for the tabs which increased the surface area to 10" x 12",
(120 sq, inches) and also eliminated the taper. These simply bolted on to the sides of the Lenco tabs with SS bolts & nuts. Only hassle was drilling the SS, which is slow but doable. This is done with the tabs mounted on the boat. I simply took the mock up that I made to the local metal shop and they copied
it in stainless.
I installed them and they definitely were a big improvement over the standard
Lenco tabs. I run pretty heavy at times though, and I decided I wanted to take
it a step further. I made up another pattern and had the shop fabricate these,
and this is what you're looking at in the pics that Joe posted and the ones in
my album. These turn the tabs into a full 12" x 12" tab. I ran these tabs all
this past season and am very happy with them. I was happy with the others
with the exception of times when I was quite heavy in the back.
I have the first generation tabs in my shop. I figured if anyone wanted them they will come pretty cheap. As you will note on the pics, the second generation tabs are on even plane off the Lenco's and have a 90 degree turn down on the outside. The original tabs had a even 15 degree downward
angle coming off the Lenco's.
The tab extensions (wings) bolt on with 3ea 1/4" SS bolts on each wing.
The actuator appear to handle them great. Not the slightest inkling of a problem.
Dusty, is a real sharp knowledgable mariner, and he is probably right in
saying it's best to use the smallest trim tab that will do the job on a boat.]
I agree completely with him, but for me I needed more tab than the 9" x12"
Lenco offered. But, the above is a great painless way to improve the efficacy of already installed tabs.
If I was rigging a new 22' CD it would be with 12" x 12" tabs without
thinking twice about it.
Sorry to be so long winded. If you want any more info or want a pic of the
first generation SS tab extensions let me know.
As Joe would say,,,,,,,,,,,,,,,,,,,,,,,,,,,,CHEERS!
