With the unfavorable exchange rate mentioned and possible import fees, you may come out OK having aluminum tanks fabricated locally,
You can see the ones I had made for my 22 in my album. Had a fab shop cut the material and make the bends, then took them to a certified welder.
All the aluminum tank fittings came from Aircraft Spruce.
By ordering the fittings myself and hauling the tanks from the fabricator to the welder, I was able to keep the cost around $200 each.
It was nice to be able to test fit the unwelded tanks to make sure the lay out would fit right, before have them welded up, 35 gallons each.
Sorry about the theft, Best of luck getting new tanks.
Tex
Tex
