1TUBERIDER
Thanks for all the insight. I probably should have gone in when the wind freshened. Still over 10 miles from port so time wise not much difference for the run out another mile. I was comfortable in it and not worried.
As to surfing the swells which I do all the time as I have done most my life, you would have been dead wrong to surf these. As boat speeds increase and you have a problem then the roll is fast.
I was running out using trim tabs to balance. One of my crew was a 250 lb guy and he was effecting balance. But when I took off to come in I had moved my tabs up and motors up for the conditions.
The speed at which I was rolling was slow and it seemed to slow for the tabs to have that effect. The swells were not only very steep, they had side chop of 3 to 4 foot and I am sure that is what caused me to heel over. There was a lot of this even on the steep faces and I also think that is why you would not have wanted to surf them.
Thatway your right on as always.
I have run many different boats. Some handle it better than others and our dorys have their limits. I was pushing limits being out in that stuff. It would have been very dangerous had I surfed the swells or tried to run with them. It was conditions we should not be out in. So slow speed was my safe speed and as always hand on throttles and hand on helm. I was still having to adjust speed as every swell picked my up and tried to launch me down or roll me over. I was doing lock to lock adjustments with the wheel to keep it going straight.
After running with it for around 6 miles I got past the bad spots where its always rougher, I was able to throttle up and resume surfing my way back. Did not adjust the motors or tabs as they were right and coming into harbor I was hitting 26 knots.
Pick your days and hope it stays nice. When it turns to crapola know your boat is capable as long as you treat it right. Be careful surfing and quartering waves when it gets big. For the surfing part, I am running down the length of the swell (quartering) or I am riding the top and staying there. I don't drop in as I would on a surf board because you can't get to the tail to lift the nose out of the broach. Your lucky if all you get is green water over the bow after "dropping in".
As always may you have a safe day. Out.
