cruiserlessvinny
Those of you who have received a copy of Boat U.S. magazine already know what this is about. This post is for those of you who don't receive the magazine.
Here is a Cliff note version of the article:
1) Ethanol enhanced gasoline doesn't loose octane faster than regular gasoline.
2) It isn't important to install a water separator to prevent water from reaching the engine (in so much as Ethanol enhanced gasoline is concerned).
3) Additives will not prevent phase separation.
4) Ethanol enhanced gasoline cannot "reach out and grab moisture"
5) E10 Ethanol enhanced gasoline is an acceptable fuel for everyday use.
6) E15 gasoline IS NOT an acceptable fuel.
7) After transitioning from E0 fuel, E10 may actually be a superior marine fuel as it tends to keep low levels of water moving through the fuel system, keeping the system "dry".
8) Don't immediately assume E10 is the problem.
9) To help avoid condensation, do not store the fuel tank empty. Fill the tank leaving a small air space for expansion and contraction.
All I know is what the article stated and have no ability to confirm or repute what is in the article. There are those who will disagree with some, most or all of what I've repeated from the article. Among the sources sited were Mercury Marine, BP Global Fuels Technology and a senior engineering consultan with Chevron Fuels. The article was written by Bob Adriance, editor of "Seaworthy"
Some of you more inqusitive and technical types may want to research what the article says and give us your take on it.
All I know is what the article stated and have no ability to confirm or repute what is in the article. There are those who will disagree with some, most or all of what I've repeated from the article. Among the sources sited were Mercury Marine, BP Global Fuels Technology and a senior engineering consultant with Chevron Fuels. The article was written by Bob Adriance, editor of "Seaworthy"
CV
CV
