With all the recent comments on which outboard to use for powering a C-Dory, I have to relate my experience to date with a 90 ETEC. Since taking delivery of a CD22 in April, I have put 114 hours on the main engine. My overall assessment at this point is the ETEC is not suitable for use in cold water climates (water temperatures less than 50 degrees F). The reasons for this assessment are based on several PM's between Dusty and I comparing the performance of his engine to mine and the fact that Evinrude could not explain the differences. Here are the problems I encountered:
a. During April, May, and part of June the EMM would return a no oil alarm after a few minutes of operation. The alarm could be cleared and the engine would operate normally if the oil system was primed using the instructions in the owner's manual. The problem cleared in June after replacing the oil tank which included all the sensors but that coincided with higher air and water termperatures. When the problem recurred the end of September, Evinrude went back to the drawing board and finally came up with the solution. Apparently the recommended XD100 oil viscosity increases so much with declining temperatures, it does not flow well enough to keep the sensors convinced the engine is getting oil. Evinrude recommended using SkiDoo XPS synthetic snow machine oil. In the last 12.4 hours of operation during temperatures ranging between 28 and 48 degrees F, I had no oil alarms. I think this problem is finally behind me.
b. Oil consumption over the 114 hours was approximately 3 times the oil consumption expected (and seen by Dusty). Evinrude examined engine reports on two occasions and after more than a month recommended the dealer look at the cooling system as their assessment the motor was running too cold. Their review of engine operating showed that it should have consumed 1.2 gallons of oil during which time I had used 3.5 gallons. The dealer found that the thermostat was allowing the engine to run 30 degrees cooler than a new thermostat. When I ran the boat with the new thermostat, the engine sounded much different, (it was quieter), ran smoother over the full rpm range, and fuel economy increase almost 30% (from 3.5 to 4.5 mpg with the same load). Prior to the new thermostat, the engine showed its best fuel economy at WOT.
c. During extensive low speed trolling the engine fouled the plugs. After trolling for approximately 2.5 hours, when increasing the throttle the engine was missing on two of three cylinders for about 5 seconds and eventually smoothed out.
d. On my last trip, the water temperatures averaged between 40 and 45 degrees F and the air temperature was between 25 and 45 degrees F. Fuel consumption declined back to the 3 to 3.5 mpg range, and oil consumption was unchanged. The engine got its best fuel economy at WOT.
My assessment is the cooling system on the ETEC does not allow the engine to reach the proper operating temperature to run efficiently in cold environments where the air and water temperatures are below 50 degrees F.
If anyone has any different experience in a cold environment, I would like to here about it.
