kelleykritters
tpbrady...just wanted to jump in here and let you know I have had the same problem with my E-Tec 90. I bought it when they first came out, this summer will be my third season with it. After the end of the first season I went to Whittier for a final fishing day before I winterized the boat. It was pretty cold. The engine ran very rough and would not accelerate much beyond idle. It finally quit running and would not even start. Luckily I was at the harbor.
I took it back to the dealer and they updated the software and changed out a temperature sensor and replaced the fouled plugs (due to running the engine rich with oil because of the old software). I did not have any problems with it this summer although I only ran it while on leave from Korea in June and July. I will be back home this winter and spring bear hunting will be the first test of cold weather ops. The final test will be next fall after a summer of use and then a final run in the cold fall weather. Needles to say I will be very careful for I lost a little confidence in my new 10K engine. But I trust I will get it back. I still like the engine and after this summers use I will probably go back to loving it.
Sorry I don't have a C-Dory I run a Alumaweld with a Jet pump...mostly up the Big Sue. I just wanted to share my story.
Thanks Jim
Thanks Jim
