Sheepshead
Yesterday my trim control (both on engine and at the helm) would only go downward, no up movement. This happenned while in the water.
I wasn't sure what the clearance would be if I were to attempt putting the boat back on the trailer. Do some folks haul their boats out of the water with the engine in complete downward position? I've never tried, and I didn't want to risk somehow hitting the ramp with my prop.
(2007 angler with original stock Suzuki.)
I fumbled around with limit switches, fuses, manual, and you tube info with no luck fixing the problem.
The swim step was too close to the manual adjustment screw to be accessed while on the water too. Darkness was no help either.
Anyway, I chose to spend a chilly night on the water and had the boat hauled out early this morning at a nearby marina with a large fork truck.
A Suzuki mechanic got it working fine without actually doing anything. He suggested maybe it was a bubble in fluid or corroded connection to solenoid.
Knowing that I could be in the same position on another trip, I wanted to know if it is doable or adviseable to haul the boat out in down position.
Thanks.
If this posts twice like always, I apologize in advance
Thanks.
