Matt Gurnsey":3eenk9ru said:The C-Dory hull shape is definately a variable in the equation, as it is a more easily driven hull. Actual performance numbers would be enlightening, especially at full throttle.
I've talked to a lot of kicker buyers who figure if 9.9 is good, 15 must be better, which isn't always the case. I'd probably make more money if I sold them the 15, but in most cases, they don't need it.
I think you are right on that Matt. When I test my 9.9 HP kicker next year, I plan to precisely calculate the length of the hull at the waterline, and perform WOT testing in calm waters with no current to see if she can go faster then hull speed. What I expect to see for sure is the law of diminishing returns applied. For all I know, which is not much, that extra 2.9 HP above what we need to achieve hull speed at 3,500 pounds total weight may only give us less than a one percent increase in velocity over hull speed!
Even though I would not need 15 HP, if I was buying a new engine, I still would consider that lightweight, fuel-injected kicker to avoid all the Ethanol problems we have on the East Coast. Out in the PNW, you people are lucky! Marinas such as Cap Sante have Ethanol-free fuel. There are no alternatives to Ethanol in the Northeast. What worries me, too, is how long the fuel has been sitting in the tanks -- particularly when we gas up early in the season.
Thanks!
Rich
