Active member
- Joined
- Nov 21, 2004
- Messages
- 5,934
- Reaction score
- 4
- C Dory Year
- 2008
- C Dory Model
- 255 Tomcat
- Vessel Name
- Meant to be
Harper - while the explosions aren't much of an issue with a alcohol stove, carbon monoxide still is (especially if the stove isn't burning with the proper fuel/oxygen ratio). I've never used an alcohol stove but I did use alcohol bunsen burners in the old days in the lab. One thing that concerns me about alcohol stoves/burners is that if one has an accidental spill/leak of alcohol, it's very volatile, ignites at a pretty low temperature and the flames are very hard to see. It's also low viscosity so it runs quickly from one area to another. It seems like a different set of dangers to me.
The advantage of diesel relative to alcohol or butane/propane is that it's not very volatile and hence is much harder to accidentally ignite.
