Dora~Jean
Active member
- Joined
- Mar 9, 2004
- Messages
- 1,519
- Reaction score
- 0
- C Dory Year
- 2003
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- CD0250171203
- Vessel Name
- Dora~Jean
I'm finally getting down to the "annoying" category of fixing things. I've had this leak since the boat was new (2003). It is located at the very rear of the cockpit floor just under the scuppers in the transom. It is somewhere in the slightly depressed well back there that's about 4-5" wide for the full width of the transom. Leaks about 1-3 cups of water per 2-day trip, varies.
About 4 years ago I attacked it with some spreadable/brushable, white roofing sealer I bought at Home Depot (1 gal). It slowed it down to about 1/2, but I don't think it adhered well, so it didn't seal well, now it has curled up and split and the leak is back to full. I also don't know if it's a dynamic crack that expands/contracts with force on the transom.
My question, what would be the best solution? I'm thinking towards several tubes of 3M 4200 (spread meticulously with a putty knife), or Boatlife, or even epoxy (but might separate if needs to be flexible), maybe all with a netting embedded for a tougher seal? I would curve it up each side of the "trough".
Any thoughts?
Any thoughts?
