There are some decisions that you have to make. Probably on a CD 22, 7/8" SS tubing will be adequate--on the 255 we had 1" tubing.
You want the Bimini to have zippers on the bows, so the top can be removed, without removing the frame.
Take the cover all of the way aft--some of the 22 owners like it all of the way to the transom, and the aft window drops straight down..
Agree with awning railing on the top of the cabin--and we used awning railing on the sides of the cabin (see photos in Thataway album 56 thru 61 photos) for a water tight seal foreward. You want to be able to zip out the first 18" to 24" of the top, for both getting in the boat, and ventillation when you need it. Velcro material over the top of the zipper where it meets with the Bimini at the first bow.
Make the front side pannels wide enough to get thru--ours are 30 inches.
24" is enough if you are slender. Make the aft side and front side (side entrance) separately.
Consider having foreward upright supports, so that the Bimni is self supporting (without straps, or having to have the front pannel attatched).
There is a Sunbrella which is waterproof--consider this vs the non waterproof. There is also Sea Mark-which is vinly coat laminated on the inside--I would not use that.
Be sure that you have enough head room under the top-and that there is adequate crown of the bimini.
Get heavy duty clear vinyl--at least 30 mils thickness of clear vinly--or Strataglass (Pressed vinly vs rolled cheaper vinyl).
Have straps to roll up all of the flaps.
Don't make the back sections too large. We have 3 sections across the back and that is better than one piece. You may also want separate corner sections--don't try and bend the vinly--make the back straight across.
You will have to make a decision if you want screens plus the windows. In that case the windows will either zip out or zip on three sides and roll up. We did't go with the screen combination, but made separate screens which will zip in place instead of the pannels.
Consider the bottom fastenings. There are three choices: the turn buttons--more expensive, and may not be as easy to get even under tension. Round snaps (the usual) and the small posts, with spring side, plate which is crimped into the cloth. We choose the latter--easier to snap with older arthritic hands. (illustrated in the album # 59).
Be sure that all seams and zippers are well re-inforced. Use the best zippers that you can buy. Use Gortex thread for all of the seams--at least on the outside (some use a inside(Bobin) of monofiliment)--the Gortex thread will last longer and delay, if not prevent a restitching.
We make sheats of old sheets of towel material for the clear pannels when they are stored below (under the matress or rolled up)--you need to avoid clear vinly against clear vinyl).
The Camper back doubles the living area of the 22 and is a very worth while investment.
