Brat map
Charlie.............I assume because all it has is the zip code to go by it does not always locate the pin at the correct address just in that given zip code because the pin is off a couple of miles from where we live.
Chris Darling":2xiiy6n5 said:
..... the pin is off a couple of miles from where we live.
Chris, if I'm not mistaken the pin is off a few miles by design by the administrators of this site. They are trying to protect each member's privacy of where they actually live. (Your zip code is never provided to anyone else).
What I really like about the brat map is that when I just looked for my vessel, I see that I now have two 22 footers at my "location". :lol: When I noticed that, I ran out to the shop to check it out but sadly there is only one parked in the shop. :cry: .
(I'm thinking that when Tom and Susan brought their 22' over last Saturday to work on it in my shop, that the administrators tracked their vessel there and never saw it depart).
In the profile section.............can another c-dory model or two be added??
Like the : PRO ANGLER
If that model is added maybe a few more folks would register their boats.
Jack
dotnmarty":gh0n63d2 said:
For some reason our zip, 98074, doesn't work either.
The zip/lat/lon database we use, is a little outdated. When there's no match to your zip code, you simply don't show up on the map.
Fortunately, it's pretty easy to modify things...I put your zip code in and selected a random lat/lon coordinate from the area, so you're there now good buddy...
We're so far in the boondocks, our zip code is: E-I-E-I-O.
