Dora~Jean":1y2q54j8 said:
I too doubted the claims. But then some 'group' of people are sure going to a LOT of effort to push this hoax. Videos of the heat generated, ultra clean burning are hard to fake -- I know it's doable. The scientific paper has been written by at least one chemist or someone quite verse in the science of molecular theory, supposedly a PhD (I know I know, piled higher and deeper).
From my reading - not too bright or too verse in molecular theory. However, people often go though a lot of effort to either perpetrate a hoax (perhaps to gain $'s from unsophisticated investors) or to present ideas which they actually believe but are not capable of objectively self evaluating. One key test of a good "scientific paper" is has it been published in a good, PEER REVIEWED journal. This work has not and it won't be (because it's crap).
Another thought that supports the 'discovery' is that they aren't claiming to solve ALL the worlds problems with it, right now they're concentrating on welding applications. Sure, he 'supposedly' converted his '94 Escort into a sort of hybrid gas/HHO vehicle, but it only enhances the fuel rather than replaces (increases 30-40%). I originally thought he was burning straight water on his 100 mile trip using 4 oz of water, but it was really only supplemental (if water only, that would be something like 3000 mpg!).
And lastly, the process of separating the Hydrogen and Oxygen atoms from H2O has been around since the 1800's as explained, only he's developed a method that significantly lowers the energy required to separate the atoms and somehow neutralizes the H-H attraction (non-valence event) -- that's the part I'm having trouble with.
You've latched onto EXACTLY the part to worry about. There is (and never will be) a methods that significantly lowers the energy require to separate the H atoms from the O atoms in water. That requires a fixed, quantifiable amount of energy per molecule that will never change.
Something about 30-35 psi pressure during the process, 220V (maybe feeds a step-up tranformer up to 10,000 volts(?)), looks to be a significant amount of current/power if it uses $1.00 of electricity per hour, my rates hover around $0.10 per kilowatt-hr.
I've often thought, what if I invented or discovered something like this, how would I, with limited resources and funds, go about unveiling it to the world while protecting my invention -- like with his patents (real?). Any way to search a public patent knowledge base for it?
There are patents issued on this "invention" - you can search for US patents easily on line for free at
www.uspto.gov. However, the existence of a patent is not in and of itself a guarantee of a working or "real" invention. It simply indicates that the US PTO thinks one has a novel idea. They don't check to see if the idea is correct or real prior to issuing a patent. If you do come up with a great idea,
1) Do a patent search on terms related to your idea. Many times, the best ideas have already been thought of and patented by others.
2) If you determine that what you have is novel and likely to be valuable, contact a decent lawyer. Then have the idea evaluated by others who can assess it. Find some true experts and have confidentiality and non-compete agreements drawn up (your lawyer would do that). Don't be surprised is experts in the area of the invention tell you it won't work etc.
3) If 3 or more experts tell you this is a good and feasible invention then file a patent.
4)After that, then try to build a company around it or sell of the patent etc. Detailed advice for this part can't be provided in the abstract other than don't go into business with people you don't know and trust EXTREMELY well.
