hank schneider
HI FOLKS
Finally have the barnacles removed - had to sand the bottom to get the little circles. Finished with 200 W/D so the surface is pretty smooth. The finish is glazed white from the sanding. I'm trying to decide between adding bottom paint of some kind or trying to refinish the gel coat. I'm not leaving the boat in the water EVER AGAIN. I think I would do the bottom paint myself but would want someone else to refinish the bottom.
Any comments pro and con. For the bottom paint there is some kind of epoxy sealer that is used. I'll call some dealers locally to see if they do this kind of thing
Thanks
Hank
Thanks
Hank
