Ancor Double Crimp Tool 702017
RichardAK
After reading all the good comments from others recently I purchased an Ancor Double Crimp Ratchet Tool. Looks like a quality product. The instructions with the tool are somewhat lacking in detail as exactly how to make a proper crimp. Some time ago one of the members posted a link to a site which gave lots of good photos and info on wiring, proper crimping of terminals and splices and other good info on marine wiring. I've searched thru old posts but was unable to locate the link. Would greatly appreciate any help in finding this site. Thanks in advance.
Richard in Fairbanks
I have not used the one at sailor solutions--but it is only a single crimp--I use a double crimp Ancor--I do have another Chinese double crimp--and it is in my "traveling box"--so far it seems as good, It has hardened dies, and is adjustable. Probably not quite the overall quality however. The double crimp makes the second crimp on the vinly covering, which acts as a strain relief. If you use adhesive heat shrink, then the double crimp may not be necessary. I only use the adhesive heat shrink where there will be the possiblity of moisture--the interior, I just use regular fittings, and often put heat shrink over them.
I begruded the expense of the Ancor unit until I had done about 20 crimps, and then it seemed like a very wise expenditure. Makes killer connections. As thataway says, it is a double crimper, and very worthwhile. I would really hate to have to trace an electrical fault through the four or five crimps leading to the battery plus terminal or the grounding system distribution panel ... the bucks spent on good crimps are money well spent.
PEX fittings are usually designed with materials of brass, although some dealers prefer to use copper, bronze or artificially designed plastic fittings for PEX plumbing. The ridges on the internal view of an installation to another. The hills, the copper ring set with PEX pipes themselves - all work to create a mutually sealing high pressure.
crimping tool
