Welcome to the C-Brats! You are a neighbor, as I keep my boat down at Chambers Bay Marina. Hope to see you on the water very soon.
If you need a mechanic for the Suzukis, the best that I have found is Doug at Performance Marine in Everett. He saved me thousands on a repair because he knows how to navigate the warranty program, and he really knows the brand. You may or may not have a warranty on your engines, but some Suzukis have a 6 year warranty. He also came to the Everett Marina and fixed a broken tilt limiter switch in five minutes, instead of replacing the switch, which I had an estimate from another mechanic for cost of the switch and two hours labor. Closer to you, Charlie at Puget Marina (which is south of Lacey on the water near the Nisqually Delta) is a certified Suzuki mechanic. For regular service, if you choose to have someone do this for you, Kevin with Kevin's Mobile Marine Service in Steilacoom is also good. He will come to you, or you can drop off at his shop. I usually do the service myself, but I have a new to me Honda 40, and he did a complete check, changed the oil, filters, thermostat and greased for $235. I have had Kevin do maintenance and repair for me off and on for almost 10 years and I've been very satisfied with his work.
Enjoy your new boat!
Robbi
