Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 0
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
T.R. Bauer":2y50z4uo said:Sunbeam,
I have rebuilt a number of auto trannies (and other parts) when I worked in a 4x4 shop in Spokane. As you noted, too much heat does them in very quickly. Just remember, your temp gauge measures the average heat of the transmission and measured by the temperature of the fluid. Some parts of your transmission are running far hotter than you think. Some far cooler. Just how hot? That is tough to tell. If it were too hot, it would have already had a major failure. Keeping cool, clean fuild in it will greatly extent the life of the transmission. I change mine every year in my E-450 V10 motorhome.
Thanks for your thoughts. I mostly see what you mean, although if the "hotter" parts have transmission fluid circulating around them (and I would hope they would, although maybe not?) then it seems like it would be reflected in the fluid temperature, especially over hours and days of towing (?) Good point on changing the fluid; I have done that regularly in my car and will do so in the van as well.
T.R. Bauer":2y50z4uo said:Trucks have ratings for a reason and if you are within the parameters, the truck/van will be fine, at least safety wise. Longevity wise, well that is another topic entirely as anytime you increase the load you increase the heat. And in doing so, reduce the longevity of the components doing the work. How much? Again, that is hard to measure, but probably not too significantly if you are in the middle of the GVCW bell curve.
I suppose another consideration, beyond a simple statement to "not go over 75% of rating" is where the weights lie. For example, my van is already at about 58% of its GCWR before I hitch anything up to it. In other words, the mass of the van is a good part of the overall percentage of my GCWR, and the boat and trailer a much smaller percentage. Maybe that means that a "flat" percentage statement is not always as accurate as it could be.
Naturally the higher rated vehicle will always be taxed less than a lower one, but for many people there are other factors that lead them to a certain vehicle (maybe they don't tow often, or they need a certain type of vehicle for daily use, etc.).
Since my van started out with 100,000 miles of no towing ever, I'm hoping I can play a bit of "catch up" without any undue wear on the transmission surpassing just the general mileage wear of the overall unit. I appreciate your fleshing out the earlier statement (made by someone else, not you) a bit.
