robhwa, where area you finding Battle Born 100 amp batteries for $699?  They have come down from the $1100 I paid for my first one....
robhwa...yes, just ordered the same one (Battle Born 100 amp 12 volts) for $699. My other two cost more like $1100 ea. Other LiFePO4 are even cheaper, and prices will likely continue to drop, making these as an alternative more affordable. Alternately, outboards are getting more expensive. I'm comparing current prices.
You have a 50 to 50 DC charger, but it appears that you have a BF 90, which only has a 17 amp alternator output.  Even the ones after 2007 only have 40 amps--and you should "leave" power for running the motor and house batteries...
robhwa...A have a newer one now. Certainly it can only pass through what the alternator provides. Since it will add the solar panels it often hits 50 amps. This DC/DC also prioritizes the starting battery, and only passes charge through to the house batteries when the starting battery is charged. A nice feature is that it will also charge the starting battery from the solar panels, which can be a problem, particularly with an old starting battery, if things sit for a long time. I keep the DC/DC charger inside the cabin since it isn't marine rated. I like this thing a lot and also have a similar setup in my camper. The RAM3500 alternator can put out 200 amps, but the 50/50 limits charging to 50 amps.
4.5 mph with the Minn Kota 80?  70# thrust equals 1 hp, and so you are getting about 1.2 hp at the max.  I have comparisons on both the 22 and 25 with Torqeedo 1103 and a 3.5 hp 2 stroke Merc.  You are pushing to get that speed with the 3.5 hp Merc...I also have experience with an 80# thrust trolling motor on my Caracal Cat, where I have compared both the Torqeedo and the Merc 3.5--more easily driven hull and cannot get 4.5 with the trolling motor.
The Minn Kota appears to be no longer made.
robhwa...Bob; I'm very curious about your speed results, as I might move to a 25 or TomCat in the future and move the 22 east. I can only speak from personal experience. I'm beginning to wonder if my motor-mounted motor actually is 80 lb thrust, or whether I was overly optimistic about my speeds. When I get out again, I'll do a better test and make sure it is at slack tide. I usually don't troll at full thrust, and only tested speed with the GPS once. My boat is usually very lightly loaded (just me), and the hull is very clean. Yes, Minn Kota doesn't make motor-mounted any more, which is too bad...I like this setup as a backup motor, and it adds little weight to my transom. It also steers with the steering wheel and autopilot.
