In 04 the factory only installed the forward bilge pumps. Some 04s had the Rules that turned on every few minutes but most were switched over to have the built in float switch. You shoul be able to separate the larger top part of the pump from the glued in screen part. The stern pump is after market and you should fix the hole. This is AFAIK.
Regards,
