Yesterday I plugged a 5000 BTU air conditioner into my 1000 watt Honda Generator.
The AC claims to need 4.7 amps (564 watts) when running. If I use the 1.8 times factor needed for starting, I get 8.46 amps and 1015 watts. Here is what I learned.
I turned off the Eco mode, turned the switch to fan On, cooling Off. Then I pushed the On switch on the AC. Next, I advanced the cooling to max. No problem. It ran without strain.
The same process in Eco mode resulted in the generator overload kicking in and stopping electrical production when the compressor tried to run.
Next, I turned off Eco, turned the power switch of the AC off, set the fan and the cooling to low. When I turned on the power switch to the AC the generator went into overload and stopped producing electricity.
From this, I concluded that while I can start the AC as described above the overload will kick in when an off to on compressor cycle occurs.
Does anyone know of a reasonable "soft start" or capacitance device that will provide the help needed for the initial power demand?
