Dora~Jean
Active member
- Joined
- Mar 9, 2004
- Messages
- 1,522
- Reaction score
- 5
- C Dory Year
- 2003
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- CD0250171203
- Vessel Name
- Dora~Jean
Well it finally came time to bite the bullet and do the valve clearance measurements on my twin Yami 80's (same engine as the 100, also same as the newer 75/90's). Reviewed the Service Manual one last time (about the 10th) before digging in. It isn't technically difficult but requires some diligence to realign the cam sprockets and timing belt, thought I'd impart some of my experience gained. You'll also need inch-lb and foot-lb torque wrenches.
First, make sure you tilt the engine a bit up so the crankcase is forward of level, this will prevent a substantial amount of oil from coming out of the valve cover when removed (called cylinder head cover). Odd this wasn't explained in the manual, engine #1 a big mess, #2 nice and clean!
When I aligned TDC on the flywheel to the separate plate marking, the cam sprocket built in marks did not align per the manual, 1 tooth off on port sprocket. So I marked their positions carefully before removing the timing belt. I then checked the other engine, exactly the same, sooooo, decided prudent to reinstall exactly as I found them since the engines run great.
Last tip, don't forget there are 2 intake and 2 exhaust valves PER cylinder (in other words, don't just measure the top clearance of each cylinder then go back later and measure the bottom ones...don't ask
The specs on my engine call for 0.008 +/-.001" for intakes, 0.013 +/-.001" for exhausts. All fell within spec :thup , thank goodness. Also checked spark plug conditions and gaps while out, all just fine.
Figure about 2 hours per engine, although 2nd engine went about 50% faster! And by the way, those engines have a great valve cover and gasket design.
