got my water system done, shore power installed,batterie charger,outlets,the boat had 2 group 24 batt,removed the one from the port lazaret and installed 2 group 31 in the space between the fuel tanks, I have been doing marine eletrical work for 15 years, cant believe the wiring that was done on this boat,a real joke! all the wire is not even marine grade wire, and the connections wow,had to make new batt cables,the old ones were not soldered,just crimped, I crimp,solder,and heat shrink every connection,never had one fail,most problems are from failed connections
