potter water
The snow finally melted enough for me to get to "Still Crazy" in its storage unit. I sat in the cabin for quite a while musing about a better way to do the Potty. (No, that's not a new dance...well, on occasion, maybe). It is just in a crappy place...no pun intended. The way we deal with this thing is to suffer with it between the bunks when we are out in the day. Otherwise, at night we move it back to the enclosure of the camper back.
As I got looking closely at space, I have the water tank under the port aft seat. On top of that is a little storage room and then the seat. It looks to me like I can remove the water tank and fix up the potty there with a lot of clever work. Then, relocated a differently shaped water tank to between the bunks. It would also serve to change the fore and aft balance of the boat in the right direction. I may even be able to set up a pump-out station port in the process. I'd also get a slightly bigger potty that has that pump out design as I've seen on other posts.
Was it just a piece of bad chicken I ate that has me thinking this way and it is an insane thought, or has someone done this or tried this? It just makes sense to me as something that should have been done with the original 22 design.
I think I can work out the privacy issues easily with the potty back there, so I don't see that as an issue. (Sorta like the 25's have done). Susan is a tiny person and I'm average in height and a smidgen over in girth, so I don't think that is an issue.
I may have to make some cardboard cutouts of me in "the position," to see if it may work ergonomically.
Thoughts?
Thoughts?
