matt_unique
Captains Cat":21vgncux said:Matt, I'm not down at the boat to look but why couldn't you remove a door glass screw and replace it with a snap screw fitting? Even epoxy it in place if necessary?
Hi Charlie,
The holes/screws around the door are larger in diameter than the holes/screws around all the other windows. I suppose I could use epoxy for the snaps but I like the idea of easy in/easy out with the screwdriver if necessary.
