- Joined
- Nov 1, 2003
- Messages
- 8,650
- Reaction score
- 0
- C Dory Year
- 1987
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- DOR22286A787
- Vessel Name
- Sea Wolf
cbull":24hmar39 said:A friend with the hvac business came by this morning to check out my plan. He had a good idea. A portable room a/c. These only have to be vented with a four inch piece of flex pipe. The unit is only 22"hx22"d and does not have a drain line. Coils in unit evaporate all condensation. Also has setting for dehu only. $299.00 plus shipping. Will run off a honda 1000 gen.
Are some of you missing the point made above about using a portable unit with an exhaust flex tube because it doesn't need a drain line because it evaporates the condensation water into the stream of outgoing hot air?
ON EDIT: I missed reading page two of this discussion when I wrote the above question. Can't simply delete it for some reason (no "X" choice).
Joe. :teeth
