Desert Dory
I'm getting ready to wrap up my windlass install and currently trying to figure the best place to mount the rocker switch. So far I like this location best for a couple of reasons.
1. I've used this socket twice since we've had the boat. Once for the spot light and once to charge my handheld VHF. Note: I'll be adding another socket lower on the bulkhead (probably) to power the fridge so I figure I can just as easily add a dual port socket.
2. And this is probably the biggest reason, I can easily reach the switch thru the open side window if needed. Note: Our forward center window does NOT open.
3. Easy enough to enlarge the existing hole to fit the switch.
4. Windlass switch plate will cover the existing screw holes.
Can you guys see any reason to NOT mount it there? Bad idea to have it on the throttle hand side? Better location somewhere else?
