Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 13
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
Hi folks,
I'm installing the new Moeller fuel tanks I got to replace my originals, and I'm interested to know what (if anything) was placed under your fuel tanks and how it has worked out.
The original fuel tanks in my boat were not installed very well, so I already know I'm not duplicating that set up. They were installed directly on the fiberglass sole - in my era boat that's also the hull - and then Starboard™ cleats were butted up against them and screwed into the hull core (ouch), with partial height Starboard cover panels attached to them. Straps were used as hold downs attached to footman loops screwed into the core on the sole. No expansion room was allowed for (Moeller recommends ~3%) and so the tank expansion had bowed the tank cover pieces and partially pulled the cleats out of the sole.
I've already got the old holes dug out and filled, so they are gone, and the new installation partially worked out and done (cleats and straps), but still have to figure out exactly what/how I'm going to put under the tanks. I heard from the builder (last summer) that they use rubber strips, and I decided I would do something like that, but I'm wondering if they will tend to move around if not glued down and/or just exactly how they have worked out. I bought a couple of sheets of rubber to cut into three or four wide strips... thinking I may use dots of 3M4000 caulk just to "encourage" them to not wiggle around under the tanks.
I considered using Dri-Dek, and did cut a leftover piece to try it, but it was kind of "slippery" so I think I'm going back to the rubber. Also it held the tanks up a bit further than necessary as compared to the cleat height. I also figure the more-compressible rubber will help slightly to support the tanks, which are specified to be completely supported (they are flat on the bottom but the hull is slightly curved).
I'll write up the installation once it's completed, but for now I'm just slightly undecided about the "under the tank" material so figured I'd see what others had and how it has worked out (or not).
