Yes the Hontoon gathering is still on. I may be speaking out of turn, but even if "Hontoon" Island State Park is not available (which it appears that it will be), there are several other alternatives on the St. John's river not too distant, and still fun locations.
Unfortunately I don't believe that "Thataway" the C Dory 25 will be there. It does have a Nico vent solar battery powered in the lens of the foredeck hatch. There are lens kits to replace the plastic. The hole for the vent fan can be drilled in a new blank, or one made.
Not a lot of boat have vents put in. We used either the Ryobi or an "Endless Breeze" fan in the fore deck hatch--hatch open, can use a trianular sun/rain shade over the foredeck and have the fan running even in the rain. We cut 5/8" dowels, flatted one side so they don't roll and place under the fan blowing in. We had insect screens either made for the hatch, or used on the inside. Also there are "window shades (horizontal) which will keep any heat or light out of the foreword bunk area. (Some are illustrated in my album).
The areas for the camber are built up with epoxy and 6oz glass, but 1708 and polyester could be used.---just not as good adhesion, but would probably be OK.
