Wakeboarding off a 19 Angler?
  • Thread starter Thread starter Anonymous
  • Start date Start date
A
Anonymous
Guest
Hello: I am considering purchasing a 19' Angler, and one of the things I am hoping it will be able to do if pull my teenage kids (one at a time) on wakeboards. I understand this is not a ski boat, but I am wondering given the hull shape and lower powered engines I usually see on these boats if pulling a kid would be an option. Has anyone done or seen this? Thanks, David in Seattle
We've had success towing inflatable tubes on the 22' with a 90. I don't know the weight and speed issues involved with wake boarding, but I would think it would work.
Matt
My 19 could do it. I have not tried it however. Make sure you get trim tabs for this and other reasons.
Tight Lines!
We have pulled teens with inflatable toys for yrs with our c-22 and now with our venture 23 witha f-115 yamaha . we have trim tabs and we use them . I dont know about wakeboarding but I think it could be performed .what speed do you need and how big of a wake do you need .
Generally Wake board boats have water ballast aft to increase the size of the wake for tricks. I think that you can buy one of these bladders and experiment to see what wake and how much ballest you can safely carry.
I suspect that even with full ballast, that the wake will be less than a wake board boat.
The second problem is the lack of a tower. The tower puts a towing position up high (to keep the rope from fouling the cockpit, plus allowing the boat to track without being pulled around by the wake boarder. You can ski behind a C Dory; best done with a bridle and pully on the bridel. This same trick could be used with a wake board, but the tricks woould not be at all easy, because the rope is low to the water, and the wake boarder would pull the boat around.
I hae solom skiied behind 25 hp--so you can do any water towing activities with low hp--but it will not be the most effective.
