Well, I tried a Lowrance LMS-337C DF. It is pretty darn quiet. There were some
minor tones on the VHF, but the units were close and the tones weren't that
objectionable. Perhaps some ferrite on the VHF power feed would help.
Except on VHF weather channel 3. The LMS-337C DF totally wipes out the
signal with a barrage of noise.
Since I bought this unit two weeks ago from West Marine, I can return it
and possibly try a different unit.
Spoke to Lowrance. The lady actually told me:
a) The unit was in compliance with FCC part B. Since part B mostly says
manufacturer should "try" to not emanate stray RF, I suppose she is
correct. I can't see anywhere where the manufacturer actually has to
succeed or face any sort of penalty. Indeed, the only penalty I can
find is if the interference is high enough and causes other people problems,
I'm not allowed to use the device. Did I miss anything?
Also, I think GPS class devices can be "self-certified", which I guess
means the FCC never saw or tested the unit.
b) She also said it was not possible to design around these limitations.
Strange statement. But, I'm guessing she is not an EE. Neither am
I, so I dropped that statement.
The problem is interesting. It only happens in chart mode, and only when
a chart chip is in the unit. I'm guessing some other processor is getting used
when the chip is installed and making the racket. Works fine using
the builtin in charts. As you change settings, and cause charts to appear
and disappear, the noise tracks. I will put a different chip in tonight and see
what happens. However, I don't have any more chips with charts on them, so
I suspect I won't hear anything. Presumably I can't copy the contents of
a NauticPath chip to another chip.
Oh, and it was also apparently shipped with incompatible levels of firmware
between the LGC-2000 and the LMS-337C CF. At least I think that's what
the head unit is trying to tell me. I'll update the firmware and see if that
allows the GPS to work.
I checked all the usual stuff. The head unit was several feet from the VHF and
it's antenna. The GPS unit itself doesn't even work, and was not connected.
The head unit was powered off of a NiCad battery pack - no wires in common
with the VHF wiring, nor were any wires particularly close.
The sound on channel 3 was basically a "roar". Really, really loud. Much louder
than the Garmin 188C ever was. I made a "movie" of this. I'll post a link when
I get it converted to an MPEG.
Also: I spent nearly 3 hours on hold with Lowrance today. Could be the
season, but "that's not so good".
If the local West Marine has some time, perhaps we'll be able to test out the unit(s)
in the store.
Mike
