Ray
- Joined
- Dec 13, 2011
- Messages
- 271
- Reaction score
- 0
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Vessel Name
- Seaweed
Playing around with some water heater formulas and suppliers on the 'net. Back of the napkin:
Let's say I just wanted 2 gallons of warm(-ish) water to shower with and I was willing to run my engine either during a trip (duh!), or idling at anchor.
The idling case above is the worst case:
The Honda BF150 says it can generate 20A while at idle (maybe).
At least one online water heater formula says that #WATTS / 2.42 * degF rise in an hour = number of gallons of water.
So, if I generate (with no battery depletion) 20A*12V=240Watts and I am willing to tolerate 30degree warmer water than the temperature of what is in the cold water tank, then:
240 / 2.42 * 30 = 3.3. Meaning a 240 watt 12V element will heat 3 gallons of water in one hour of the engine idling. There are lots of 100, 200, 300, and 600W, 12V elements on the net.
A 2 gallon tank would then only take 2/3 of an hour of idling, I assume. Any errors in the calculations could be assumed to be taken up by the house battery bank.
Seems to me a dual element (120V for shore power and 12V for engine/battery) and a smallish 2-gallon water tank with TONS of insulation might be an interesting thing to consider.
