My solution for the anchor rope part of the rode twisting is to use all chain on the part of the rode that is used most commonly.
100 ft of 1/4 inch G-4 High Test anchors my CD most all the time, although I have 200 feet of New England Ropes 3-strand nylon back up spliced in for use as needed.
The chain most definitely doesn't like twisting, and the weight of the anchor and chain will immediately unwind/untwist itself once the anchor frees the bottom and hangs freely.
(100 feet of 1/4 inch G-4 weighs 74 pounds.)
An added plus is that with the heavy chain and a good anchor, you usually don't need the 7:1 type of ratios usually recommended for anchoring, which take into consideration all types of bottoms, storm conditions, overnight use, 180 or more (cumulatively) wind shifts, U.S.Navy Seals Operations, and the Great Final Cataclysmic Plate Techtonics Realignment.
With the chain, your boat will wander or "search" less at anchor as well, an added benefit. (Swings in a smaller radius.)
Plus, the chain will not slip in the teeth (pockets) of the windlass, period.
That's my story, and I'm stickin' to it! :lol:
Joe. :teeth :thup
Joe. :teeth :thup
