WeekiTiki":5w06t8ad said:
I'd think there'd be water intrusion through the self bailing port
I assume you know it's just the splashwell that is "self-bailing," not the cockpit. At any rate, water intrusion into the splashwell is certainly not a problem. Not enough water could accumulate in there to put the ports below the waterline. I worried about lots of things in more than 6,000 miles up and down the Inside Passage. The splashwell was not one of them.
Thought the 23 was self bailing
Looked at one at Hontoon and the drains in the transom were under the water line and they weren't on the keel
But then it had a lot of extra weight on the stern at that time too
Yes, you certainly could put enough people or stuff in the cockpit to drive those drain ports below the water line, but that would only allow a little water to enter the splashwell. Until you put enough weight in the boat to drive the full height transom wall or the gunnels under :shock:, you will not sink.
I may have sounded a little cavalier about recommending the twin F70's. Just to be clear, while I whole-heartedly endorse them on a 23, and they are quite light engines for their horsepower, I have no experience with the 22.
