Well-known member
- Joined
- Oct 2, 2011
- Messages
- 5,108
- Reaction score
- 78
- C Dory Year
- 2009
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- UWH25301J809
- Vessel Name
- C-Traveler
Before leaving home my kicker, a Yamaha 9.9hp, was giving me some trouble stalling and only running for a short time. I assumed maybe it was due to low fuel in the tank. When we launched at Lake Powell the main, a Yamaha 150, started up and ran fine as usual. However pulling into the dock at the marina, a very short distance from the launch ramp, it stalled. It started back up after I pumped the fuel hose bulb and seemed to run fine again. I left it running while going to the marina store. By the time we came back it had stalled. I got it running again and we headed across the way from Halls Crossing to Bullfrog Bay. The main Outboard stalled again. Thinking perhaps a main fuel filter issue, I changed that. Started it back up and got on plane but then the engine sputtered a few times. Figured I’d be looking for a mechanic in Bullfrog. But then the motor started running fine again. I did several back and forths in Bullfrog Bay and the motor continued to run fine so we pressed on to Moki Canyon at planning speed. I had tried the kicker again while in Bullfrog Bay and I continued to have problems with it. Since I had filled the fuel tank back in Iowa ($1.75/gal, best gas price on route.) I prayed I didn’t have bad gas. Arriving at a nice beach stop for the evening the main outboard started acting up again as I was idling in gear. Once tied up secure for the evening I started trouble shooting again. I found fuel leaking out of the kicker’s small inline fuel filter when I pumped its fuel hose bulb. In the end I found a small split in the seam that had caused the trouble on both engines. Both run off the same main fuel filter so apparently enough air was being drawn thru the split in the kickers inline filter to also effect the main!
Moral of the story, the tiniest fuel leak in the system can cause havoc with all engines in the system!
Colby
Colby
