Salmon Fisher
Member
- Joined
- Aug 7, 2009
- Messages
- 885
- Reaction score
- 1
- C Dory Year
- 2004
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- CD025035K304
- Vessel Name
- Kim Christine
My next project before hydraulic steering is installing Bennett M120 sport tabs. Roger, C Squirt, has been kind enough to walk me through process. He used West System epoxy. I will be removing core in pilot holes with a dremel and filling with epoxy. What is the best way to accomplish that in the transom that is vertical? Use of a syringe and then taping over until epoxy cures? I suspect I need to use a heat lamp/flood light arrangment to put some heat on it.
Am I on the right track? I will also need to fix bad screw job in cockpit on the existing fuel tank holding pieces as they have pulled out. Any suggestions on that would be appreciated, too. Just finished the cooler holder over splash well with Work Release Jim's help. Consulted True Story's photos, too. Sure is nice to get cooler off floor. Oh, am also building floor boards for cockpit. Sure is fun doing projects on the boat to make it better.
Thanks all!
Patrick
Thanks all!
Patrick
