Thanks for correcting this Joe--I know that sometimes I forget--but this was very short term! I would not be as comforatable with the hull of a 22 having the transom twenty eight inches from the back of the bunks. First there is the weight of the engine, It would depend on how much bunk support there is. The worry is a "hook" in the hull. This used to more prevelent in cold molded and fiberglass boats which didn't have stringers.
The C Dory hull is very strong--but the 25 has wooden petitions under the deck, which act as stringers (even though they are not called stringers by the factory). The Tom Cat 255 spreads out the eginge load by the Armstrong bracket, plus the twin narrow hulls, have an "I" beam effect.
With my lift the back of the hull is 18" from the back of the bunks--and I have been watching it very carefully. In a year there is no change or set of the hull. But the boat is not being trailered in this situation--when I trailer the TC, the bunks are the full lenght. The CD 25 bunks on my trailer are about 3" from the transom and this seems to be fine.[/b]
