Transom table
There is a name on the back of the table you pictured. That is "Burnewin". Do a Google search, and you will find their website. That will give you a way to purchase what you want.
The bar is custom made-and there are all sorts of ways to put a bar across the C Dory splashwell. Either have one fabricated ($$$) or use your ingenuity and come up with a way to do it cheap.
Like you, I've been considering rigging up a table and have been researching the options. I have two Burnewiin stainless gunwale mounts, and they're pricey but nice. I use the gunwale mounts for multi-function rod, downrigger, and crap pot puller holders.
A slightly more budget friendly table option might be a Magma table attached to the Burnewiin mounts and bases.
https://magmaproducts.com/collections/all-fillet-tables
https://burnewiin.com/products/tb5730-table-legs-pair
https://burnewiin.com/products/gm300-mount
https://burnewiin.com/products/rk300-rail-mounting-kit
Vs.
https://burnewiin.com/products/cb5315-cutting-board
We installed the large Burnewin Table on the TomCat between the stern railings and even added a dingy motor mount to it. They are built very well, worth the money.
There are pics of on page two of our album.
I'm going to start looking around but it's the bar that I think is going to be most useful. Then I'll be able to clamp anything I want on it. I was hoping that something would have been made already. Thanks for the tips!.
Some C-Brats have pieced together a rail using off-the-shelf components. I just bought some railing sections and fittings from LFS / Go2Marine to build a roof/kayak rack, and the tubing is fairly sturdy.
https://www.go2marine.com/shop-all-...are/deck-hardware/handrails-and-rail-fittings
At a glance, the following components might work depending on your use case:
Tubing: https://www.go2marine.com/Stainless-Steel-Tube-7-8-and-1-Diameter-Sold-by-the-Foot
Hinges: https://www.go2marine.com/sea-dog-top-mount-deck-hinges-stainless-steel-90-degrees
Tubing Ends: https://www.go2marine.com/Sea-Dog-Top-Fittings-Stainless-Steel-1-4-Pin
If you go that route, make sure you get the by-the-foot Morse Industries tubing. The Taco tubing is flimsy in comparison.
