Bob. Where do I get ss pipe?
You can buy SS pipe or tubing at many sources. Because of shipping costs, I tend to buy it at West Marine. But check on line and there are multiple sources. You can buy what ever wall thickness you want from schedule 10 to Schedule 80. As far as the "best" for marine use: 316 has the better resistance to corrosion. But 304 will work also.
Harvey, I am sure that your tubing is much stronger. Mine does fine for lighter coolers, and the generator. I have done the same on 3 boats and never had a problem, even with my weight on it at times.
BTW, this is a seriously cool boat.
. Referring to "Cochise", Steve Dashew's FPB 78 his current and last power boat which is 86' long and only 20' beam. I doubt that "Cochise" would ever be confused for a C Dory. The hulls and dynamics are so much different. Cochise's hull remains a V, to rounded V aft to almost where the prop shafts emerge, then the stern is flat, almost like a long swim step, the HP to weight ratio are way off, Cochise is a displacement boat. The C Dory is a planing boat. Look at the stern--fully open, and very narrow for the length--C Dory enclosed and wide for the length... this 86 footer has very fine lines. Sorry, but the dynamics are entirely different.
I have known Steve (Skip) and Linda Dashew since the early 1970's. They are one of the brightest cruising couple in the world. His innovations and his voyages are epic. He has contributed a great deal to the world cruising base, starting with his first Deerfoot sail series. I have been privileged to have been aboard several of his boats from the first "Beowulf" (32' Class D sailing Cat), Intermezzo (Columbia 50), Deerfoot 70 and "Wind Horse", but not Cochise. His Marquesas Islands to San Diego (over 3000 miles) in 12 days in the 80' sailboat Beowulf is a record which I doubt will ever be surpassed, with a boat handled by a couple! (OK, I know that "foilers" are faster!)
Steve is probably a year or so older than I am. He and Linda are still cruising almost full time just the two of them, in an 86 foot boat! His father lived to be 96, and I would be surprised if Steve is still not sailing at that age!
I digress, back to the C Dory and transom. I have never taken any serious water over the transom of any of our C Dorys. I believe That the deck mold for the 22 remains the same, but I could be wrong. I believe the 23 has the full height forward part of the splash well. I find getting out over the splash well of the 25 (with the full height) vs the 22 is about the same. But the 25 has a raised cockpit and is theoretically self bailing. Taking serious water over the transom is a factor of how the boat is handled and many variables in the sea state. The C Dory line has a huge amount of lift aft, because of the beam, flat bottom and agility with the high HP to weight. Once a cockpit of a 22 (or 22) is filled with water, you have a very serious situation!
