Blueback
- Joined
- Oct 2, 2004
- Messages
- 235
- Reaction score
- 0
- C Dory Year
- 1990
- C Dory Model
- user_field_choice.c_dory_model_16_Angler
- Vessel Name
- Blueback
I know this subject has been discussed to some degree, but I thought I would share my take on preventive bearing maintenance. I have served a Machinist apprenticeship where the understanding of how critical bearing maintenance is was stressed and demonstrated, with many failed bearing repairs. I moved on to marine engineering and retired as a shore based Power Eng. Having said that, I am still learning about all things with an open mind at 80, so take it that way.
This is not intended to be a treaty on the bearing subject here, just a little insight into what I have experienced with trailer bearings.
First off: Bearings and bearing seals were made, in my youth, by USA companies which were of high quality like "SKF" etc. It's has been said that good bearings were the cornerstone of mobility for the advancing military after D-Day, as Allies advanced across Europe. These bearings were under strict quality control with a method for tracking back to the factory assemble line and even to the workers producing bad bearing. So quality was high.
Not so today; China and south east Asia spins out cheap bearings and bearing seals and have flooded the North America market with them. The problem is quality varies greatly in these bearings products and that's the problem we face with our boat trailer bearings. Will they last, or let you down in a very inconvenient fashion? Therefore, the point of writing this is to say that for most of those who tow any distance, a yearly winter check of your trailer bearing is a good practice to get into. Then in the summer get into the habit, when you pull into a rest stop, to put your hand on your wheel hubs for any abnormal temperature present. That will give you a clue to a possible bad bearing developing. When you get home jack the wheel up and spin it, listening for any noise from the bearing. Do not rely on Bearing Buddy's by pumping a whole wack of grease into the hub. If its a noisy bearing it must be replaced-period. Now to Bearing Buddy's -some swear by them -some swear at them and most professional's in the trailer industry say BBs are a false sense of security as, with a hub full of grease who wants to do a full yearly visual inspection of the bearings. Whereas, pulling the outside bearing cone, washing, and inspecting a bearing takes about 10 minutes if only the bearing is packed with grease. Then if you find brinelling marks (bar marks) - or any pitting - replace both inner and outer bearings and of course the inner seal.
