Gene and Mary, Ahhha, the dreaded swivel jack, landing gear freeze-up and failure. So, after going thru 2 Wilton jacks, and now my third, Dutten-Lainson (which I thought would be a better one, I am with you on this one too.
Not sure what you meant by "the stock swivel jack" as those are parts not made by EZ Loader, but there should be a brand name on that jack and those are the people you need to contact. If not, call EZ Loader and get the info from them.
I replaced my first ones, first upgrading to a dual wheel, higher weight rating, and then after that one froze up, again upgraded to a "better" jack. I launch and retrieve in salt water so do a thorough wash down after each dip, and I have greased until the whole column is now packed with grease and it still is frozen. (Believe me, a good floor jack is worth it's weight here.)
When the Dutton-Lainson 6800A jack seized, I called the company. Their cure, I buy a $13 fix kit, and they would send me some Youtube links to see how to fix it. YUP, I had to buy the parts. Next I will see if I can follow the UTube bit and make it work again.
I sure hope there are some better cures out there than doing this job every year or so.
