Active member
- Joined
 - Oct 2, 2011
- Messages
 - 5,022
- Reaction score
 - 9
- C Dory Year
 - 2009
- C Dory Model
 - 25 Cruiser
- Hull Identification Number
 - UWH25301J809
- Vessel Name
 - C-Traveler
I think the problem with the folks in the story brought to us above, on the Highlander, is folks that really didn't know what they were doing in the first place, and put their trust completely in to sales.  Regarding electric brakes.  No, the Highlander does not come prewired, nor is there even a helluva lot of room to install a controller.  None the less, I was able to install a very good system, including the wiring.  It's really not rocket science, but it does require some mechanical ability.  Towing a flat faced trailer behind any vehicle is going to add a lot of wind resistance.  It's one thing to pull a rather somewhat aerodynamically shaped boat, quite another a large travel trailer of the same weight.  And many times trailers weigh over specs, once they are "wet" & loaded.  I don't tow any faster than conditions allow, or top speed of 60 mph, although I've pushed it to 75 passing, or even 65 locally on the highway.  I've never felt that the boat was pushing the Highlander, even in panic stops.   I'm not going to pretend here that the Highlander can tow anything up to 5000 lbs.   But at this point in my life, I don't need to pull anything else than my CD-22 or a small utility trailer.  I've been considering a 3/4 ton truck (with camper), or a small motorhome, simply for the reason I miss the "motorhome" lifestyle I had some time ago.  However, the very reason I downsized to the Highlander involved gas & maintenance costs, a downsize in boat (from the SeaRay 268), and a change in lifestyle (no longer "camping/land traveling" as much).  With retirement, I'm inclined to travel more again, however for the cost of a small motorhome or large truck, numerous hotels and motorhome rentals can be had...with out the cost of ownership.  Thus for me, the Highlander remains to be the best choice at this time, and again, is very capable of the job at hand that I use it for.
I too enjoy and appreciate the comments and experience shared here on C-Brats. I can get a little defended, and maybe offensive too, but in the end I think that's just an effect of any kind of social media. Colby
