There is more discussion on this thread about the 1003 motor.
http://www.c-brats.com/viewtopic.php?t= ... sc&start=0
Also, this is what I posted in that thread about our experience using the 1003 as a kicker on our 19 angler.
We had the first chance to test our 1003 model on the boat Sunday morning.
Liberty Bay in Poulsbo
Sunny and glassy (no wind)
tide not a factor (high peak)
We started with the battery at 99% and tested slower to faster so the range estimates taken from the display would be a bit higher if we had started with that specific speed from the beginning.
With our heavily loaded 19 angler (2.5 adults,full fuel, and loads of stuff) we saw the following numbers:
30 watts = 1.2mph - 1kn - 17 hours on standard battery 20.4 statute mile range estimate
60 watts = 1.6mph - 1.4kn - 8.5 hours on standard battery 13.6 statute mile range estimate
97 watts = 2mph - 1.7kn - 5 hours on standard battery 10 statute mile range estimate
199 watts = 2.5mph - 2.2kn - 2.5 hours on standard battery 6.25 statute mile range estimate
509 watts = 3.3mph - 2.9kn - 1.1 hours on standard battery 3.63 statute mile range estimate
937 watts = 3.9mph - 3.4kn - 30 minutes on standard battery 1.95 statute mile range estimate
30 watts is the standard charge rate from the included charger whether it is connected to 120v AC or 12v DC. We will charge the battery from the house batteries on the boat and because it can charge while running, one could run at the 30 watts rate for a looooong time or just keep it connected to extend range at a higher speed.
60 watts is an estimate of the fast charge rate (I don't currently have one to test) for the available 85w fast charger. This higher charge rate is directly from an AC source or a higher voltage DC source at 24v+. The details of that DC feed are in the works to be tested but my first step-up converter turned out to be a dud. Range extending at this charge rate should also be possible.
We were happy with the thrust provided by this motor for our 19 and no longer have ANY anxiety about using it for a backup motor. The limited speed of less than 4mph means we will not affectively go against a strong current but that will never be necessary. We will have to think more like a sailboat when relying on the Torqeedo. It will be more than capable of pushing us to safety and away from dangers as we motor for the nearest safe anchorage and ride the tides as needed.
The approximately 6 mile range at 2.5mph is really the sweet spot for us and the distances we are normally dealing with in the Puget Sound and BC. With a charging cord connected, we could always stop for a while at the first safe spot we reach and try to "fix" the issue we are having while the range grows slowly back toward the 100% mark again. Our house bank could charge the Torqeedo battery at least twice more without any trouble. When our safety is concerned, our urgency to get there is no longer a factor.
Now I just need to refine the motor mounting.....
